Dragonsmith 1.1.1 CodeWarrior update
Download: http://archive.info-mac.org/dev/src/dra ... w-updt.hqx
--========================_13102812==_
Dragonsmith CW Update updates Dragonsmith 1.1.1 for CodeWarrior C++.
The full Dragonsmith kit (available separately) lets programmers easily
create drag-and-drop applications for use in System 7 or greater. This
archive contains project files for CodeWarrior 4.5 as well as replacements
for 8 of the source code files, incorporating changes needed for
compatibility with Apple's Universal Headers and CodeWarrior C++. Users
of Symantec C++ may benefit from this upgrade as well, although use of
Dragonsmith 1.1.1 in Symantec C++ 6.0 or greater has not been tested and
is therefore not fully supported.
This update was produced by Francis H Schiffer, 3rd. Support for the
CodeWarrior version of Dragonsmith will be provided (when possible) by the
original author of Dragonsmith 1.1.1, Paul Hoffman.
Dragonsmith is freeware, Copyright (c) 1992-1994 Paul M. Hoffman. Programs
created using Dragonsmith may be distributed without restriction.
NOTE: "Drag-and-drop" here refers to the original Apple Event variety, not
to the more recent Drag and Drop for Macintosh (aka the Drag Manager).
Paul Hoffman | Francis H Schiffer, 3rd
[email protected] | [email protected]
[email protected] |
- - - - - - - Dragons do not enter into this message - - - - - - -
Content-Type: application/mac-binhex40; name="Dragonsmith_CW_update.cpt"
Content-Disposition: attachment; filename="Dragonsmith_CW_update.cpt"
