Re
Re
Post by Info-Mac » March 3rd, 1993, 11:00 am
Download: http://archive.info-mac.org/dev/src/dink-class-c.hqx
[Downloaded from AppleLink--I'm not the author, Mark Gross is. Contact him
via [email protected].]
DinkClass is a small Think C5.0 (and MPW C++) application framework for
system 7 applications.
DinkClass is now offered as shareware.
If you use ANY of it in your own software, then you must pay a one time fee
to Applied Technical Software (ATS) of $45. In return you will get
unlimited rights to distribute any COMPILED programs created using part of
DinkClass source code. However; the distribution of any source code
derived from parts of the DinkClass software MUST BE DONE WITH APPLIED
TECHNICAL SOFTWARE'S CONSENT!!!! (So, give me a call.) You also get, for
the $45, two free maintenance updates of the basic class library, of the
basic demo applications, of the documentation, any extra demo applications
I may have created (DComDemo a CTB demo, for instance), the MPW C++
supporting files (.make, .r, .c files renamed to .cp, etc.), and telephone
and EMail support. Maintenance updates go out in December and July.
The DinkClass ShareWare distribution package includes:
o Think C 5.0 projects with well commented source code for 2 applications
and the Template project.
o Think C 5.0 source files for the base class library.
o Off-line documentation of the key features implemented in the class
library, all conforming to the Feature Oriented Documentation standard
developed. Features documented in this way include:
All the applications, Scrolling Windows, Event parsing, File and I/O
handling, Clip board support, Menu Handling, and more.
o A readme file.
o A directory "Listings" file of what constitutes this ShareWare distribution.
o A shameless flier soliciting contract software development work for ATS.
o The executable form of the CTB demo application.
o This "Posting note"
Feel free to redistribute this shareware package of DinkClass as you wish, but
ALL OF THESE FILES MUST STAY TOGETHER UNALTERED IN ANY RE-TRANSMISSION OR
DISTRIBUTION OF THIS SHAREWARE PACKAGE!!!!!
p.s. it would be nice if someone could but this package in some of the
INTERNET repositories (like SUMEX)
Mark Gross 12/31/92
19548 W. Cambridge Rd.
Mundelein, IL 60060-1005
Telephone: 708.949.0925
Software engineering services in OOD, OOP, C++, C, MacApp, TCL, MPW,
ThinkC. Initial project development intended for transfer to client with
continued technical support. Turnkey, prototype, and consulting projects
accepted.
I know, its another shameless plug.
p.s. If you would like to use DinkClass in an educational setting contact
me for FREE transient licensing arrangements.
--Brian Bechtel [email protected] "My opinion, not Apple's"
orrow.stanford.edu!stanford.edu!ames!haven.umd.edu!darwin.sura.net!wup ost!micro-heart-of-gold.mit.edu!bu.edu!Shiva.COM!world!aep
Newsgroups: comp.sys.mac.programmer
Message-Id:
References:
Organization: The World Public Access UNIX, Brookline, MA
Lines: 625
Apparently-To: info-mac
Resent-To: backmod
Here is the directory scanning code. Written under MPW 3.2.
--------CUT HERE------------------------------------------------CUT HERE------
