DiagramC
DiagramC
Download: http://archive.info-mac.org/dev/src/diagram-c.hqx
DiagramC (for the Macintosh, in C)
The original version of DiagramC can be found in any alt.sources archive,
it is provided in Fortran source code and it works quite well. I translated
DiagramC.F to DiagramC.c using MacF2C and MetroWerks 5.5. However, MacF2C
does a very good job of converting the source to Compiler independant code;
it should work on either Symantec or MetroWerks...
I retain the rights to the C version. Future versions will be conversions
of the C source, not the Fortran version. It seems like the original author
left no copyright or anything, and he seems to hate C, so I don't think he
will have a problem with me keeping this version.
NOTICE
Because this package was compiled using F2C, it will require F2C to
recompile. There are two libraries that F2C creates in order to bridge the
gap between Fortran and C. These files were simply too big to include in
this package. Sorry... I will work on excluding as many of the fortran
functions in future versions as I continue the conversion to something
readable...
FUTURE VERSIONS
Future versions of DiagramC will have a drag & drop interface via DropUNIX,
a library I wrote to help me convert UNIX file processing source to a Drag
& Drop app for the Macintosh. Future versions will also have a Preferences
dialog allowing you to set your default controls once and let every file
dragged onto the application use them.
COST
This version of DiagramC is being released as Email-ware (damn I do hate
these stupid little *-ware phrases)... If you download this (even if you
DON'T USE IT) please email me at:
and tell me that you got it... Thanks...
DiagramC (M/C) ©1995 Ryan Davis, Zen Spider Software
