DBL Pascal Lib.
DBL Pascal Lib.
Post by Info-Mac » February 22nd, 1994, 11:00 am
Download: http://archive.info-mac.org/dev/src/dbl-library-p.hqx
//* Posted by Kenneth A. Long *//
//* Author's comments follow. *//
David B. Lamkins
Source code released by David B. Lamkins, Feb. 1994.
Here's a collection of Pascal routines that I've developed and
used over the years. All of these are for THINK Pascal version 4.
Not all of these are production-quality - some parts are only
minimally tested.
Terms of distribution are followed by a brief contents list:
* This software is provided as-is, in the hopes that you will find
it useful.
* The software is provided without warranty of any kind.
* I am releasing this software to the public because I have no
intention of further developing it; I will not answer questions
regarding this software.
* This software is Copyright David B. Lamkins.
* I grant permission for you to reuse this software, provided that
my copyright is included as prominently as your own, in the form
"Portions Copyright 1994 David B. Lamkins."
* The Macintosh type/creator signatures used for the programs are
registered with Apple Computer, Inc. in my name, and may not be
reused.
* You may not release derivative programs under their original
names of PwrSwitcher, TimeTeller, or LaunchFile XCMD.
Brief Contents
Agendas
Animated Cursor
Async Sound
Call Chain
Checksum
CRC
Debugger Presence
ICON control CDEF
sicn control CDEF
Pop up menu CDEF
Error Signals
Fast Bit Vectors
Hash Tables
INIT Shell
Layer Manager IF
Levenshtein Matching
Short Fractions
Submenu Delay
Preferences
Queues
RSRCRuntime Bug Fix
SFGetFolder 6
String Lists
Transactions Mgr
Dialog Utils
Pop up Utils
Block Zero
VM Traps IF
David B. Lamkins
---------------------------CUT HERE-----------------------------
