Crooked Mouse 1.0 (source code)
Download: http://archive.info-mac.org/dev/src/cro ... e-10-c.hqx
Crooked Mouse is a fun little INIT which will cause your mouse to move
at an angle 45 degrees counterclockwise from the angle you moved it.
This INIT is free and is distributed under the GNU General Public License;
this archive contains complete THINK C 6.0.1 source code and project files
for the INIT. If you do not have FTP access, e-mail the author for a copy of
the INIT, the source code, or a list of other programs by the same author.
The address is [email protected].
This code demonstrates the basics of writing and installing a VBL, and the
manipulation of undocumented low-memory globals. This code should work under
any system, with any monitor, on all Macintoshes. Please report any
bugs/comments/suggestions to [email protected].
Crooked Mouse 1.0 is copyright 1993, Mark Pilgrim, MerriMac Software Group.
