CPreferences 1.0 - Class for CodeWarrior PowerPlant
Download: http://archive.info-mac.org/dev/src/cpr ... 10-cpp.hqx
CPreference Class 1.0
by Richard A. Bray
President
Compu-Phobic, Inc.
AOL: CompuFobic
I (that's me, [email protected]) am *NOT* the author of this class. This
is a simple C++ class for implementing preference files with
CodeWarrior's PowerPlant class library. Here's an exerpt from the docs:
This class was created to simplify the creation of preference
files for an application.
The object is very general and simple to use.
When MW C++ supports templates, I will rewrite the class to support
them. This will allow an easy way to create multiple preference files
for applications that need them.
Use of CPreferences:
1. Add "CPreferences* mPrefs" to your application class.
2. Add this line to your constructor.
mPrefs = new CPreferences('CPI6', "\pTextStreamer 3.0 Prefs");
// 'CPI6' is the creator of the file.
// "\pTextStreamer 3.0 Prefs" is the name of the file.
3. Add this line to your destructor
delete mPrefs;
4. In order to access the data in your data structure, you will
need to add accessor functions to CPreferences.
In the next version I will also include methods for using a Preferences
dialog.
