Cdev Tester 7.0
Cdev Tester 7.0
Post by Info-Mac » March 4th, 1993, 11:00 am
Download: http://archive.info-mac.org/dev/src/con ... r-70-c.hqx
* System 7.0 Control Panel tester
* )1993 Triplo Software
The Control Panel tester is a source code file that you can use to test
your cdev code resource files under the THINK C 5.0 environment with little
difference from the operating system.
Any comments, questions, bugs, etc. please report them to:
Triplo Software
c/o [email protected]
If you think I expect money from this, you're crazy. It's freeware, I guess.
Have fun. Just credit me where you think it's due.
----------splice 'n' dice here------------
