ControlPanel-0.9.4.sit.hqx
Download: http://archive.info-mac.org/dev/src/con ... -094-c.hqx
Folks:
I get to postin' here and there and forget where I put everything. I
scoured a.s.m., merit and sumex and found this NOT!
So here it is. will post to a.s.m., too.
Author: Ken Worley.
Type: Think C 6.0.1 project.
Content: Source for a sample control panel, sample INIT and sample
patch. Built examples of each.
Additions: Ken Long added Think C 5.0.4 projects, to make it easier on
the po' folks.
I tried these and the CP and INIT *both* show their icons at startup.
The CP won't open unless loaded, but has nice features for a shell. I
also tried building all three and there were no problems with that.
-Ken-
-------You are not Morg. You are not Imorg. What are you?-----------
