Routines that open blocks as filestreams in ThC 5
Download: http://archive.info-mac.org/dev/src/bbe ... ev-kit.hqx
The attached StuffIt Deluxe archive contains documentation,
interfaces, and sample source code that developers can use to write
BBEdit extensions. This updated version features revamped
documentation, a new "universal" include file, and information and
samples on how to write PowerPC-native extensions.
Extensions written with this kit are compatible with BBEdit and BBEdit
Lite, version 3.0, and, if properly written, are also
backward-compatible with older versions of BBEdit.
The extension developer's kit is also immediately for anonymous FTP
from ftp.netcom.com, in /pub/bbsw, and from ftp.std.com, in
/pub/bbedit. If you have a URL-aware utility such as MacWEB,
Anarchie, or Mosaic, you can directly access the developer's kit with
one of the following URLs:
ftp://ftp.netcom.com/pub/bbsw/bbedit-30-dev-kit.hqx
ftp://ftp.std.com/pub/bbedit/bbedit-30-dev-kit.hqx
Bare Bones Software, Inc. Internet: [email protected]
Rich Siegel Michael Fryar Patrick Woolsey
President & CEO Chief Operating Officer Chief Technology Officer
Here's a file to put into /mac/development/sources/snippets on
mac.archive.umich.edu. Compress it as you please.
blockio.c and blockio.h by Art Eschenlauer
Routines to open blocks of memory as simple filestreams under ThinkC 5.0.4
Here are some routines to open a block of memory (Ptr or Handle) as a simple
filestream (they do not support disk oriented commands like rewind and seek).
I wrote these for porting unix software to ThinkC 5.0.4 using the standard
libraries. I don't know if they would work on later versions of ThinkC std
libraries. Bugs, comments, flames, etc. to [email protected].
Disclaimer:
