Palm Synch-n-Quit 2.0
Download: http://archive.info-mac.org/dev/osa/pal ... uit-20.hqx
This script runs the Palm Serial Port Monitor (SPM), then quits it after
a the Conduit Manager quits so you don't have to remember to quit it and
get the nasty crash on wake problem. If you follow the instructions, you
can then just hit an F-key, hit synch on your Palm, and not worry about
remembering to quit or having to go to a menu to select a script that
quits it. This script is set for a 15 second delay, meaning you have 15
seconds once you have the SPM running to get the Palm in position and
tell it to synch.
