Download: http://archive.info-mac.org/dev/osa/mlauncher-b2.hqx
Thanks for downloading mLaunch. This small script will install
a daemon launcher in your startup items, so that MLDonkey will
run from the
time you startup to the time you shutdown. If you dont like the
feature provided, simply remove the "mLauncher" file from your
/Library/StartupItems directory.
I am a new developer, this may be the only script I will write.
But, if you would like to see improvements, new features,
donate, or just want to
bash me, my email is Thanks!
Version history:
9/12/2003 : v.b2
Easier to open
Made files executable, thus "working."
First public release
9/1/2003 : v.b1
Initial Release as mLaunch v. b1
