Download: http://archive.info-mac.org/app/bus/qif-convert-19.hqx
QIF Convert converts Quicken Interchange Format (QIF) banking or
credit card transaction files, adding Quicken categories based on the
description of each transaction. It is useful for converting QIF
downloaded from online banking or credit card web sites before
importing them into Quicken. To convert a QIF file, just drop it
onto QIF Categories.
You can configure QIF Categories as a browser helper application for
files of type application/qif to have it invoked automatically on
downloaded QIF files.
QIF Convert converts each transaction in the QIF file by: 1) Deleting
any existing category, and adding a category associated with the
transaction's description; 2) Removing the plus sign from transaction
amounts (because not all versions of Quicken allow plus signs); 3)
Optionally adding an indication that the transaction has cleared; 4)
Optionally extracting a check number from the description (unless the
transaction already has a check number) and using it as the check
number that Quicken will recognize; 5) Optionally changing the
description and category to values associated with the combination of
the original description and the amount; and 6) Optionally allowing
you to confirm the transaction, where the description and/or category
can be changed, or the transaction can be deleted. You have the
option of store transactions from one ore multiple accounts in the
same output file.
System requirements:
* System 7.5.3 through 9.1
For more information, please read the documentation enclosed, or
visit the QIF Convert Web page:
http://homepage.mac.com/jplw/QIFConvert.html
