PICTButton CDEF 1.3
PICTButton CDEF 1.3
Download: http://archive.info-mac.org/dev/lib/pic ... f-13-c.hqx
PICTButton is a CDEF (control definition) that allows you to use PICT
resources as buttons instead of the drab black and white buttons that you
are used to. You can use it just about anywhere. It has been tested on
various machines and includes a small application demonstrating its use.
Please remove all previous versions of PICTButton from your archives.
Thanks!
______________________________________________________________________
Celestin Company, Inc., 1152 Hastings Avenue, Port Townsend, WA 98368
Telephone 360 385 3767 -- Fax 360 385 3586 -- http://www.celestin.com/
send a blank message to [email protected] for an index of our products
