LControlPanel & Friends
Download: http://archive.info-mac.org/dev/lib/l-c ... d1-cpp.hqx
A delightful controll panle;
mix with equill tonnage of PowerPlant
)1995 Chris K. Thomas. All Rights Reserved.
Reach me at [email protected]
Version 1.0d1
This is a preliminary release of LControlPanel & Friends, a very small
set of classes which enables the use of PowerPlant LPane subclasses
(including, of course, LViews) in System 7 Control Panels. Your LPanes
require no modification to work with LControlPanel & Friends. (Yeeha!)
There are two advantages to this approach:
1. Copland will require control panels to be applications of a special
type. The same LPanes you use in your LControlPanel will work just fine
in your LControlPanelApplication at some later point (sooner than you
think! yeeha! On Schedule!).
2. Control Panels are incredibly annoying to write under normal
circumstances. PowerPlant soothes the pain and increases the power.
