Download: http://archive.info-mac.org/dev/lib/cde ... -202-c.hqx
This is the updated version of CDEF-DeBugger.
CDEF-DeBugger 2.0.2 A handy way to debug your controls from within you
application. No longer do you have to create code resources, compile
them and then insert them into your application to determine if they
work. All you need to do is insert your control into this Think C
template and debug away! Currently it is a Think C 7.x project, but
easily could be ported to other C Compilers. Also could be used to debug
other code resource like MDEF's and LDEF's. Version 2.0.2 is now PowerPC
compatible.
