Download: http://archive.info-mac.org/app/bus/mid ... er-132.hqx
Midius ProjectPlanner is a program for making time schedules (Gantt
charts). It's a simple but yet powerful tool for planning any kind
of project, though it's most useful for small projects.
The 1.3 to 1.3.2 releases corrects the following bugs (and adds
some new features too):
+ Corrected a bug related to exporting project as a picture.
+ Also corrected a bug that messed up the team member menu when
click-and-hold in the responsible column.
+ Corrected a bug sometimes causign a crash during save operations.
+ Also corrected bugs causing write to address 0 (which people with
EvenBetterBusError installed noticed).
+ Corrected a bug related to selecting columns to be shown. Could
cause the computer to hang.
+ Added a feature to automatically resize the window if it was to
large for the screen being used.
+ It is now possible to make time schedules back to 1904 as opposed
to previous versions where it was impossible to set a start date
prior to 1987.
+ Added possibility to change the font and size of the font. (These
options can be found in the Schedule menu.)
+ Added possibility to change the row height (which is kind of
necessary when you can change to larger fonts). The row heights
cannot be changed individually but all rows must have the same height.
+ Added support for the forward delete key.
+ Now the columns can be reordered by drag-and-drop (only exception
is the row number column).
+ Corrected a bug in the calendar dialog, where time was displayed
as tenths of hours instead of hours, when selecting a field.
+ Name of summaries can now be displayed in the Gantt chart just
like ordinary activity names by option-click on the activity (or
summary) with the select tool.
+ And corrected lots of other major and minor bugs.
The program is distributed as shareware and a single user license
is 35 USD.
