Download: http://archive.info-mac.org/dev/lib/blu ... 0-demo.hqx
'BlueLibrary Pack1' is a set of 5 libraries for the PowerPlant
framework by Metrowerks. They are designed to work with
PowerPlant 1.3 and 1.4
The best one is CPreferenceDialog, just get it and you'll see...
that this class is design for creating a preferences dialog box
a la the CodeWarrior IDE with panels attached to icons
and that you can create it using Constructor v2.x.
You can copy this package, distribute it where you want but it
must remain in its unmodified entirety it can be put on disks,
CD-ROMs and magazines that charge a reasonable fee for the cost
of distributing it. I would appreciate a copy each of any such
support of distribution. It can be put also on BBS, Compuserve,
Internet,...
The latest version of 'BlueLibrary Pack1 v1.0' is available at
this internet www location:
http://www.insa-lyon.fr/People/AEDI/ccauser/library/
