BeachText 2.0
BeachText 2.0
Post by Info-Mac » July 4th, 1995, 9:00 am
Download: http://archive.info-mac.org/dev/lib/bea ... ev-kit.hqx
BeachText 2.0 is High-Performance text editor that is supported
2-Byte Character.(test only Japanese)
character is...
-High-Speed-
In pursuit of the High-Speed. We keep the speed-down to a minimum
resulting from the High-grade functions.
BeachText is most suitable for use on Power Macintosh.
BeachText is especially good performance on Power Macintosh.
-For the new functions of Mac OS-
Not to mention for Inline Input by System 7.1,for Drag&Drop
and QuickDraw GX printing.
-User interface-
BeachText is more useful because of acquiring a work palette.
-A substantial search function-
Multi-File Search and Multi Nested Folders Search.
-BeachGEAR-
"Plug In Module" is used in BeachText for easy to use the additional
functions. So you can use a extending function, just put in BeachGEAR.
In addition,you can construct your original "GEAR" because of open the
interface of "GEAR" to the public.
-Document-
You can paste picture on the document and open a picture document.
BeachText can save the additional information about the document,
you can resume editing of your document in the last condition.
-Else-
Multi Window
Wrap Line
Paste picture
Prepare document of the TeachText,etc.
[Environment]
BeachText need to run...
1) Macintosh Plus and later
2) System 6.0.7 and later (If you use KanjiTalk 6.0.7,
BeachText changed into the English environment)
3) More 640KB free memory. (If you are using 68K version,more 384KB
free memory)
4) HardDisk
