AGMenu 1.0
AGMenu 1.0
Download: http://archive.info-mac.org/dev/lib/ag-menu-10.hqx
AGMenu is a small library which manages the Guide (or Help, or Balloon
Help, or Question) Menu for you, letting you stash your application's
Apple guides in their own folder, out of the way of inquisitive users.
AGMenu places your guides in the correct locations in the menu, and uses
the same criteria that Apple Guide 2.0 uses when decided which guides
should be included. Integrating AGMenu into your application is trivial
and can often be done in less than an hour.
Further information can be found at
NB: AGMenu is not an Apple supported product.
Peace,
-tre
Tom Emerson Cambridge R&D
Senior Software Engineer Apple Computer, Inc.
