Window Tools 1.6.1
Window Tools 1.6.1
Post by Info-Mac » January 22nd, 1997, 11:00 am
Download: http://archive.info-mac.org/dev/card/wi ... ls-161.hqx
Window Tools is a set of scripts which installs in your Home stack.
They create a menu from which you can easily access all your open
stacks, windows and pallettes. You can show and hide windows,
close stacks from the menu and add stacks to a list of stacks
you frequently use. You can also re-open closed stacks by simply
selecting its name from the Window Tools menu. Window Tools is
simply indispensable when it is installed!
New in this version is abilty to close stacks from the Window
Tools menu as well as a fix to a bug which would cause Window
Tools not to work.
Daniel Stødle
Yellow Lemon Software
