Including Tax Submission
Download: http://archive.info-mac.org/app/bus/inc ... ax-151.hqx
Including Tax 1.5.1
Including Tax! is a freeware pricing calculator that allows you to
calculate tax-inclusive prices given a dollar value and a tax rate,
or tax-exclusive prices given a tax rate and an inclusive figure. You
can also calculate international prices based on exchange rate values.
The results of the calculations are recorded in an editable text
field, which can be copied, printed, pasted into a spreadsheet,
and/or manually annotated.
One additional feature is the ability to use addition ('+') and
multiplication ('*') symbols in the Amount field. For example, you
can automatically add 7.72 and 3.35, and calculate the tax and
tax-inclusive total by typing '7.72+3.35' in the Amount field. This
version does not support the mixing of addition and multiplication -
use one or the other, not both together.
We recognise that the functionality provided by Including Tax! could
easily be duplicated by using a spreadsheet application, with a
couple of simple formulas. However, sometimes, a spreadsheet is just
not convenient, especially when you want to quickly calculate a
couple of totals. Some people will find this application of no use,
others, whose need will be solved by Including Tax!, will find it
very useful!
Including Tax! will run on all PPC- based Macintosh computers. It
requires 900K of free RAM, and a minimum of System 7.1.
A version for Windows 95 (minimum) is also available.
