Stack-Peeker-22
Stack-Peeker-22
Download: http://archive.info-mac.org/dev/card/st ... ker-22.hqx
Keywords: Scripts Stacks HyperCard Player Peek View Modify
Shareware $5
This fast, feature-laden, but easy to use HyperCard script viewing utility
now has MORE POWER. You can now view and modify the CONTENTS of locked
and/or hidden fields.
Stack Peeker 2.2 allows you to view and MODIFY the "stack" script of a
target stack, AND do the same to the scripts of ALL cards, backgrounds,
buttons and fields anywhere in a target stack, even in stacks which has
been set up to prevent access to the scripts. In this upgrade, you get the
power to modify the contents of every field on every card in a stack
regardless of whether the field is locked, hidden, or both.
Using Stack Peeker, you can create a text file containing the scripts of
every object in a stack. This text file can be opened and printed using any
of the popular word processing or "works" programs. Stack Peeker also
includes the ability to create a searchable library of individual scripts.
All of the above functions can by performed while running Stack Peeker with
the HyperCard PLAYER, even though the Player does not support scripting!
So now, Player owners can view and experiment with the scripts which make
HyperCard stacks work.
Stack Peeker may now be conveniently registered through the Kagi Shareware
service using their REGISTER program which is included with Stack Peeker.
Registration may be made by credit card via E-mail or fax (with
automatically encrypted credit card information for E-mail users), or by
credit card, cash or check (in U.S. dollars) via snail mail.
