ScriptExtractor
ScriptExtractor
Download: http://archive.info-mac.org/dev/card/sc ... ractor.hqx
ScriptExtractor expands the functionality of HyperCard vers 2.4
This is primary a tool for advanced HyperTalk programmers.
The card window as a palette
"Level"
Simply switch to userlevel 5 and open msg window and the variable watcher
"Open"
Open a stack and extract scripts of stack, bgs, cards and buttons.
"Menu"
Install scripts in the target stack to install a menu "*"
This will allow to export scripts from within the stack.
Note, that this is different from the menuItem "Install Menu..."
Btn scripts are not exported... (yes, its a little bit of chaos, up to now :-)
"Help"
Open help
Menu "Special"
"Info..."
Get info about a stack
"Compress Stack..."
Delete unused lines in the script
"Zapp commends..."
Delete commends
"Install Menu..."
Install a menu to remote edit scripts.
To use the menu, ScriptExtractor must be open.
Choose menuItem "Remove me" otherwise.
Functionkeys
F1: Message Window
F2: Variable Watcher
F3: Message Watcher
F4: Toggle palette
F5: Change creator of text output
Default is TBB6 : Tex-Edit Plus
Arrowkeys:
Switch the palette to the four corners of the screen
