Download: http://archive.info-mac.org/dev/card/pl ... -23-hc.hqx
The Player Helper stack provides a way to create up to 20 buttons and 20
fields on each card in your own stack using only the HyperCard Player
(available free from Apple Computer).
You can develop and edit HyperTalk scripts for the buttons and fields
you create. You can also create and edit card scripts.
You can create as many Helper cards as you want in a stack.
