trying to sync three channels but only two works
oliversashio
- 2 MB
hi, my array sync only allows me to sync two videos on two screen, the third one is only playing and looping the first frame on the video. i need it for emergency please help
Re: trying to sync three channels but only two works
Hey there, few questions…
Are all three displays connected to one computer? Or are you using a combination of ArraySync server and ArraySync Client on networked computers?
Can you attach a screenshot of your ArraySync window(s)? Also what codec are these video files using?
oliversashio
- 2 MB
HI, I attached the screenshot on the email I sent you hope it will help for you identify the problem? please get back to me as soon as you can, i am on an emergency situation thanks
oliversashio
- 2 MB
hi I just sent another email for further questions
thanks for the help
thanks for the help
Since your situation seems to be rather unique I will discuss this further with you in email, thanks.
