should I upgrade or buy?
peterbilt
Post by peterbilt »
Hi all -
I have an older iMac - an iMac 7,1 running 10.6.8 - that love. However, I'd also love to upgrade it to Sierra or at least El Capitan. I just want the latest software and to be able to sync with my Apple TV and iTunes.
What's the verdict?
Thanks
Re: should I upgrade or buy?
You should upgrade. That model is 10 years old now, technology has progressed a long way since those days.
Gabbymac
4 MB
Post by Gabbymac »
Before Upgrade, check please, will your Mac support new OS system because you can get some bugs
