MyCCursor XFCN - HyperCard & Supercard
Download: http://archive.info-mac.org/dev/card/my ... r-xfcn.hqx
MyCCursor. XCMD for HyperCard® & SuperCard®
Copyright © 1996. Tracy L. Hinshaw, Parnassien Language Software.
MyCCursor is an XCMD for HyperCard and SuperCard which allows you use
colour cursors in your stacks/projects. Colour cursors are stored in the
resource fork of your stack/project and need only be identified by ID to
work.
MyCCursor is probably most effective when used with SuperCard where
persistent cursors are supported (i.e.: set the lockcursor to true)
although it can be quite useful in HyperCard too.
MyCCursor is provided as freeware for personal use. If you do
incorporate MyCCursor in your stacks/projects, I would appreciate an email
message just to let me know how and where my program is being used.
If you intend to use MyCCursor in any commercial/shareware product, you
must contact the author for licensing and distribution approval at:
Tracy L. Hinshaw
P.O. Box 142
Kellogg, IA 50135-0142
http://www.netins.net/showcase/fornlngz ... rnals.html
