MsgMem 1.1
MsgMem 1.1
Post by Info-Mac » June 18th, 1997, 9:00 am
Download: http://archive.info-mac.org/dev/card/msg-mem-11.hqx
MsgMem is a HyperCard utility. It allows you to store, reinsert and
execute commands entered in the message box. All commands executed via
the message box are saved to a menu until a user-definable threshold is
reached. Then the older commands are erased. You can also execute
commands without reinserting them in the message box.
MsgMem is shareware. More information on pricing is included with the
package.
If you have any questions, comments or bugs, please report them to
either or .
For updates, other products from Yellow Lemon Software and more, check
out the YLS web site, located at
This version fixes bugs that would disable MsgMem from running at all.
It now runs, though it still has some minor bugs which are mainly
related to HyperCard limitations.
Daniel Stødle
http://home.sol.no/stoedle/YLS/YLS.html
