EZContacts v1.04
EZContacts v1.04
Download: http://archive.info-mac.org/app/bus/ez-contacts-104.hqx
EZContacts ReadMe
Get the latest version at http://www.sphosting.com/ezsoftware/
EZ Contacts is a simple database application to manage all those names,
addresses, telephone numbers and email addresses that we all scribble down
on scraps of paper, then customarily misplace! It is simple, fast and
reliable. This is the full and complete version; the software is not
crippled in any way and does not require a serial number or password to
obtain further functionality. EZ Contacts is donationware. If you continue
using EZ Contacts after 10 days, please make a donation. Making a donation
will not only make you fell better about using the software, but will
encourage me to continue to enhance and improve this application as well as
develop other simple solutions to everyday problems. Donations can be made
by Paypal (preferred) at www.paypal.com (my ID is: [email protected])
or by check or money order at:
Peter Leonard
Montreal, Quebec
H3X 1T4 CANADA
System Requirements:
Macintosh
68k or PowerMac, System 7 or later, 4 MB or RAM available memory. Screen
resolution set to 1024 x 768.
PC
Windows 95 or better. 4 MB of available memory. Should work with most
configurations. Screen resolution set to 1024 x 768.
**Note: The database file (EZCOntacts.DB) is interchangeable between the Mac
and PC versions. THerefore if you have a Mac at home and a PC at work (or
vice-versa), you can simply update the database once and transfer the
database file (EZContacts.DB) back and forth between the 2 computers.
Version History
Version 1.04
Added functionality by intergrating Internet search functions. Search for
addresses and telephone numbers directly from EZContacts. Search Canada411
for Canadian residents and use Yahoo People Search to find US residents.
Also, perform genealogical searches with Ancestry.com.
Version 1.03 & 1.031
Corrections made to the tab order and minor adjustments to the way the
application behaves.
Version 1.02
This version supports many new fields including work and family related
fields. I also corrected a bug that caused the program to hang when deleting
the last record.
Version 1.01
First public release
Corrected some minor bugs
Version 1.0
Initial non-public release
Questions, comments and suggestions welcome. Please email me at
©2002 Peter E. Leonard
