Download: http://archive.info-mac.org/dev/card/hc ... ger-11.hqx
It provides developer buttons that are linked to a card or background of
the target stack and contain handlers that are written and used during
development, but are not part of the final release.
These handlers may be used to ...
Layout the buttons and fields of a card or background;
Draw borders and dividers;
Type titles and labels;
Run a test;
Import data from a file.
These handlers are saved in the Project Manager and are available
when you develop the next version of your project.
Documentation and an example stack is included.
New in version 1.1 - A Tools popup button that allows you to:
Record the tools windows that are open and their locations so that
they always re-open where you want them.
Do a Script Search (ss) from an Ask dialog instead of the message
box.
This allows you, for example, to simply type 'field "fieldName"'
instead of '"field ""e&"fieldName""e'.
Also includes a copy of Script Scribe 2.3.
