Need help with Itunes problem on MacBook Pro
NeanBean
Post by NeanBean »
I updated my system on October 16th and right after that i couldn't open my iTunes . i tried opening it from Finder and it just won't work .
Re: Need help with Itunes problem on MacBook Pro
Do you get an error message? Or does it bounce in the dock and then do nothing? Anything more specific?
mark_42
Post by mark_42 »
How about some specifics on the computer? CPU, RAM, HD, Year of manufacture and if you did a backup before updating (presumably to Yosemite)?
