Is "Saving a Preset" the same as "Saving a Project"? If I create my video wall in Array sync, then save it as a preset, I should be able to open that same preset and get the videos that were assigned in the beginning phase?
If this is the case, I am having problems opening the presets. Something will open, however, the videos I originally assigned across the displays do not come up.
Thanks
sonyusr
Saving and Opening Presets....
Re: Saving and Opening Presets....
Are they perhaps stored on a network drive that is not being mounted at startup?
