Arraysync interface
nightstand
Arraysync interface
Post by nightstand »
We are using a collection of LED monitors - 25 arranged 5x5. They are daisy-chained via ethernet. Can Arraysync see them in this type of layout via ethernet from my MacBook Pro running Maverick? We have other Macs, running various OS's.
Thanks
Randy
Re: Arraysync interface
Just for clarification - are you saying they're all attached to other Macs? Like, a bunch of Macs on the same network, powering 25 displays?
If so, then yes.
nightstand
No, they are 25 different LED screens that are daisy-chained via ethernet and power.
We are using a http://www.led-card.com/product_info.ph ... cts_id=160
to send media to it.
The 25 panels need to be configured by another external device that is controlled by a PC.
The device is a: Linsn SB-8 Sender Box
I Do NOT want to have to use Windoze at all, especially with the nature of what we are using the monitors for.
PLEASE HELP! I hope you have a Mac solution in your memory banks or bag of tricks.
ArraySync can achieve what you want but each of your 25 screens would have to be directly connected to a Mac. Probably not the solution you're looking for, sorry!
nightstand
No, definitely not. They are all independent monitors that work independent of a computer.
