Hello,
Since I upgraded my iMac to OSX 10.9.1, Word and PP appear every time I log on. Not a major issue, but quite irritating nonetheless. Any suggestion how I can change this?
Thanks a lot,
Arie
Word and PP appear automatically after switching on iMac
Arie Speksnijder
- 2 MB
Re: Word and PP appear automatically after switching on iMac
Check your login items under accounts in System Preferences and look for something different that might be causing this. If you don't find anything there look in the Library folders in the root directory, System folder and your home folder for the StartupItems folder(s). Peruse them for possible culprits.
Mavericks is pretty buggy so I wouldn't put this weirdness past it.
Mark
Mark
Arie Speksnijder
- 2 MB
Solved! Thank you Mark.
Glad to help! Just out of curiosity, where did you find the culprit?
Mark
Mark
