ACvisual stack -- ideas for AddColor transitions
Download: http://archive.info-mac.org/dev/card/ac-visual-hc.hqx
Type: HyperCard stack
Requires: 8-bit colour, HyperCard 2.2 or newer
AddColor's transitions, when chosen from the menu in the color palette,
are assigned to a card, so that you get the transition whenever you go
the card. But what if you wanted to have separate transitions, so that
the transition depends on what card you started out from? The problem is
solved in the simple scripts of this stack. Full on-line documentation
of what goes on.
