Flash player for iPad
I'm being asked for adobe flash but cannot download what is the replacement for ipad
Re: Flash player for iPad
There is no Adobe Flash for iPad or any other iOS device. Adobe has discontinued Flash for mobile platforms.
OK, that leads to another question. A couple of years ago Apple said that Flash Player was the #1 cause of trouble with Apple computers, and then Apple said that it was backing the new HTML5 standard, as a replacement for Flash Player. And so, what is the current status of HTML5?
I use Puffin browser it handles flash sites very well. does that help? there are other 3rd party apps that support flash (browsers mainly)
@ thor0128
Thanks, but I have serious reservations about using Flash Player on my newer Apple computers, no matter how it could be supported. In fact, I signed on to this board, Info-Mac, BECAUSE of the troubles I experienced after downloading Flash Player onto a 2011 Mac OS X Lion. Maybe the newer Apple computers can handle Flash Player better than those of a couple of years ago, but I am not about to take any chances, thank you.
Sorry I was referring to ipad solution that I use everyday. not a MAC OS X solution... Flash is a pain in the backside
