Barres II.0.0
Barres II.0.0
Download: http://archive.info-mac.org/app/bus/barres-II00.hqx
Barres is a simple barcode generation application for Macintoshes. It can
generate the following type of barcodes: UPC (12 digits), EAN13 (13 digits),
and SCC14 (14 digits).
With Barres, you can generate barcode graphics yourself, simply and
inexpensively, using your Macintosh. The resolution-independent file can be
saved in a standard epsf file or in a PICT image. Barres generated graphics
have been tested with the most important illustration or desktop publishing
softwares (XPress, InDesign, Photoshop, Illustrator, ...) in a professional
environment.
... WHAT'S NEW : The software is now "carbonized", it is compatible with Mac OS
X, and works with Mac OS 9. It is possible to save the barcode graphic in the
professional format epsf (encapsuled PostScript), in addition to the PICT
format. The height of the barcode can be changed from 10% to 999% of the
nominal size.
More information can be found at :
http://www.log-1.com/Barres/en/
... PRICING AND AVAILABILITY : Barres II.0.0 is usable for all Macintosh running
Mac OS 9 or any version of Mac OS X. It is available immediately.
The product is Shareware and priced at only $30 for one license.
A fully functional demonstration version is available from our Web site
http://www.log-1.com/BarresVIIen
The demo version is unlocked after purchase.
You can buy today directly online via Kagi:
http://order.kagi.com/?4UA&lang=en
JT . Gueux @ log - 1 . com
