Hi all
I have a Apple Mac Mini G4 1.25Ghz 512mb 80GB and I want to know what monitor can I use or do I need to get for this Mac? I tried using my TV with a HDMI cable and it worked
And then quit working.
Thanks for your help. Kerry
I have a Mac Mini Question?
Re: I have a Mac Mini Question?
A TV isn't a good choice for a computer monitor. You can just walk into any Best Buy, Walmart or other computer store and buy any standard PC monitor, plus adapter if appropriate.
Hi
Thanks for getting back to me. Do you know what kind of adapter I need for my Mac Mini?
Kerry
Kerry
It depends on the monitor. Many typical PC displays have old-style VGA ports. More modern displays have DVI. Super new cutting-edge displays have DisplayPort or Mini DisplayPort. Different generations of Mac MIni also have different ports. Your Mac Mini should have a single DVI port. So for most quality displays, you won't need an adapter just a cable. If you get a display that only has a VGA port, then you'll need a DVI -> VGA adapter. And so on...
Hi
Thanks for your help, I just went and got a monitor with DVI port and now all is well.
Kerry
Kerry
