iwork
Trayon5
iwork
Post by Trayon5 »
Hi, this is probably embarrassing simple but is Keynote a tool in iwork or are they separate apps and purchases? Thank you
Re: iwork
Trayon5 wrote:Hi, this is probably embarrassing simple but is Keynote a tool in iwork or are they separate apps and purchases? Thank you
Keynote is part of iWork, although Apple now sells the three applications separately on the Mac App Store. Before the Mac App Store, you would buy a box labeled "iWork" in a regular retail store.
