Lost password Ipod touch 5th gen.
do7aa
Post by do7aa »
My daughter forgot the password she put on her new ipod touch 5 th generation.
Is a way that I can reset the password??
Plz help !!
Re: Lost password Ipod touch 5th gen.
Not without wiping all files and settings. Are they backed up to her computer?
do7aa
Post by do7aa »
Losing data is not an issue. There is nothing on the ipod. It is new.
BrockObama
Post by BrockObama »
Then just restore your iPod. (plug the USB cable into a computer then plug your iPod onto that and click the restore setting, of there is nothing on the iPod there would be no need to backup, and yeah that should work.)
