PowerBook G4
appleaddict
- 4 MB
PowerBook G4
I got a old PowerBook G4 off eBay, works great but the seller left all their personal info and did not remember their password. They included a copy of SnowLeapord but as you know it is an Intell based OS, is there a hack to get around this and force install SnowLeapord on a PowerBook?
Re: PowerBook G4
No, it isn't possible. Leopard is the maximum OS on any PowerPC Macintosh.
appleaddict
- 4 MB
Re: PowerBook G4
Ok was hoping someone had made a hack, I ordered 10.3 the stock OS restore it in my name then maybe upgrade to Leapord later. Wish the used MacBook Pros would drop in price I'd like to run Mountain Lion
Re: PowerBook G4
You should have just bought Leopard since it'll surely be pretty cheap. 10.3 is going to be so outdated you won't be able to run basically anything on it. That's like crazy old, from 2003.
There isn't a *hack* for Snow Leopard since the incompatibly is much deeper than that. You'd have to get all the source code for Snow Leopard and compile it yourself for PowerPC since there is non PowerPC code in Snow Leopard at all.
appleaddict
- 4 MB
Re: PowerBook G4
Got 10.3 for 20 bucks cheapest leapord was 80 I got this to see if I like OS X I havenot worked with Macintosh since college and it was like 8.1 I think. I wanna save up and get a MacBook Pro if I like it
Re: PowerBook G4
There's Leopard DVDs on eBay under $50. Using Panther in 2012 isn't going to be a very pleasant experience at all. You'll be stuck with Safari 1.3.2 for example, which will barely be able to handle even basic HTML5 and CSS3 websites.
