Quit Ext
External modules for 4D.
Quit Ext
Download: http://archive.info-mac.org/dev/db/a4d/ext/quit-ext.hqx
To: [email protected]
X-VMS-To: IN%"[email protected]"
Quit4D(Expr) Expr is a numeric expression
Quit allows you to automatically quit a 4D database by formula. The Expr is used to specify what you want to do
If your database is running under multi-user mode 2 and 12 are not supported. 1 and 11 work respectively like 3 and 13. Quit4D works correctly under multi-user mode only if the database has been opened with a password with an associated startup proce
