PlayString External update
External modules for 4D.
Download: http://archive.info-mac.org/dev/db/a4d/ ... 11-ext.hqx
This is an update to the PlayString external for 4th Dimension. The
original had occasional crashing problems when used with the new Apple
Sound Manager 3.0. This file should replace the original in the appropriate
archive.
PlayString is a free and simple external procedure for 4th Dimension that
will play sounds associated with characters in a string. The sounds and
characters used by PlayString are user configurable. PlayString also allows
control of the Macintosh sound volume.
Some possible uses are:
Dialing the phone
Reading characters aloud
Creating Voicemail-type messages
Enjoy!
_________________________________________________________________
Brian Hutchison
