SAM Install Scripts 1.2
Software virus protection & removal utilities and information.
Post by Info-Mac » January 9th, 1994, 11:00 am
Download: http://archive.info-mac.org/vir/sam-ins ... pts-12.hqx
In response to some complaints on the Internet regarding
the un-intuitive installer script for Symmantec's popular
virus program SAM* 3.5. Symmantec's script will not do an
installation if you have replaced the original Virus Definition
file. Go figure! I don't know about you, but I update mine
when necessary on the original disks. I have created my own
scripts which should work fine. I have System 7.1, and I know
it works there, but I also have created a System 6 installer.
It should work fine, but I have no place to test it. Only the
target folders have changed. These scripts only recognize the
Virus Definitions file on the Decontamination Disk, so make sure
that is where you place your updated Definition file. Also, it
you are using System 7 or greater, SAM* Intercept and SAM*
Intercept Jr. are both placed in the Extensions Folder.
If you decide to use these, please just e-mail me and let me
know that you have used it. Also, let me know about any
troubles you may have. I can be reached at the following
addresses:
or
My snail mail address is
William Waits
1471 Ashwood Way
Lawrenceville, GA 30243
SAM* is copyrighted by Symmantec Corp. I have no affiliation
with them.
Al Bloom, this one's for you!
Version History
-1.0 Initial Release
-1.2 Added better icons to custom window
Read Me file reflects more accurate data
