Kernel panic at boot, safe boot works fine
paolobrolin
Post by paolobrolin »
Hello all,
I'm a new face here and have been fortunate enough to never really need support, however at this point, I'm completely lost. First of all I want to apologize if my English is bad, Swedish is my native language.
My specs:
MBP 5,1 (late 2008) 15.4"
CPU: Intel Core 2 Duo 2,53 GHz
Memory: Apple native 4GB
Boot ROM Version: MBP51.007E.B05
System Version: Mac OS X 10.7.2 (11C74) Lion
Kernel Version: Darwin 11.2.0
SATA HDD: ST9250410AS Seagate Momentus 7200RPM 250GB
I have a very annoying problem that I dont know how to solve. When I try to boot my MBP normally I get kernel panic before getting to the login-screen. The kernel panic occurs 1-2 minutes into loading while the gray Apple-logo still is on screen.
Booting in safe mode works just fine (wifi, wired network and other critical os x functions works - While gfx-, audio-, spotlight-, etc. kexts are disabled). This problem occurred a few months ago while using the MBP normally (e.g. browsing the web). Since then I have done the following troubleshooting:
1. Switched to other HDD:s with both Snow Leopard-/Lion set-ups (fresh installs, same kernel panic)
2. Tried to reinstall from USB (same kernel panic)
3. Zapped PRAM
My thoughts: Some non-essential component in my MBP is malfunctioning, but since it works just fine in safe boot mode I figure that if I disable/remove the right kext(s) it should boot up fine in normal mode as well? (without the functionality of the component(s) that is disabled)
Im having a hard time to localize the origin of the error since I dont have any experience of interpreting Mac kernel logs.
Maybe you guys have any answers? Ill be eternally thankful for any thought, advice och help I can get!
I have recorded logs from two different crashes:
Kernel panic #1
Picture of KP1:
https://docs.google.com/open?id=0B39rsO ... kxMzdiMWQ3
All Message Log (KP1):
Code: Select all
2011-11-28 11:44:58,000 bootlog: BOOT_TIME 1322477098 0
2011-11-28 11:45:05,000 kernel: Darwin Kernel Version 11.2.0: Tue Aug  9 20:54:00 PDT 2011; root:xnu-1699.24.8~1/RELEASE_X86_64
2011-11-28 11:45:05,000 kernel: vm_page_bootstrap: 942082 free pages and 32766 wired pages
2011-11-28 11:45:05,000 kernel: kext submap [0xffffff7f8072e000 - 0xffffff8000000000], kernel text [0xffffff8000200000 - 0xffffff800072e000]
2011-11-28 11:45:05,000 kernel: zone leak detection enabled
2011-11-28 11:45:05,000 kernel: standard timeslicing quantum is 10000 us
2011-11-28 11:45:05,000 kernel: mig_table_max_displ = 73
2011-11-28 11:45:05,000 kernel: AppleACPICPU: ProcessorId=0 LocalApicId=0 Enabled
2011-11-28 11:45:05,000 kernel: AppleACPICPU: ProcessorId=1 LocalApicId=1 Enabled
2011-11-28 11:45:05,000 kernel: calling mpo_policy_init for TMSafetyNet
2011-11-28 11:45:05,000 kernel: Security policy loaded: Safety net for Time Machine (TMSafetyNet)
2011-11-28 11:45:05,000 kernel: calling mpo_policy_init for Sandbox
2011-11-28 11:45:05,000 kernel: Security policy loaded: Seatbelt sandbox policy (Sandbox)
2011-11-28 11:45:05,000 kernel: calling mpo_policy_init for Quarantine
2011-11-28 11:45:05,000 kernel: Security policy loaded: Quarantine policy (Quarantine)
2011-11-28 11:45:05,000 kernel: Copyright (c) 1982, 1986, 1989, 1991, 1993
2011-11-28 11:45:05,000 kernel: The Regents of the University of California. All rights reserved.
2011-11-28 11:45:05,000 kernel: MAC Framework successfully initialized
2011-11-28 11:45:05,000 kernel: using 16384 buffer headers and 10240 cluster IO buffer headers
2011-11-28 11:45:05,000 kernel: IOAPIC: Version 0x11 Vectors 64:87
2011-11-28 11:45:05,000 kernel: ACPI: System State [S0 S3 S4 S5] (S3)
2011-11-28 11:45:05,000 kernel: PFM64 (36 cpu) 0xf10000000, 0xf0000000
2011-11-28 11:45:05,000 kernel: [ PCI configuration begin ]
2011-11-28 11:45:05,000 kernel: console relocated to 0xf20010000
2011-11-28 11:45:05,000 kernel: PCI configuration changed (bridge=6 device=3 cardbus=0)
2011-11-28 11:45:05,000 kernel: [ PCI configuration end, bridges 7 devices 19 ]
2011-11-28 11:45:05,000 kernel: AppleIntelCPUPowerManagement: (built 21:08:10 Aug  9 2011) initialization complete
2011-11-28 11:45:05,000 kernel: FireWire (OHCI) Lucent ID 5901 built-in now active, GUID 002332fffed252a2; max speed s800.
2011-11-28 11:45:05,000 kernel: [IOBluetoothHCIController::setConfigState] calling registerService
2011-11-28 11:45:05,000 kernel: ERROR: FireWire unable to determine security-mode; defaulting to full-secure.
2011-11-28 11:45:05,000 kernel: mbinit: done [64 MB total pool size, (42/21) split]
2011-11-28 11:45:05,000 kernel: Pthread support ABORTS when sync kernel primitives misused
2011-11-28 11:45:05,000 kernel: com.apple.AppleFSCompressionTypeZlib kmod start
2011-11-28 11:45:05,000 kernel: com.apple.AppleFSCompressionTypeDataless kmod start
2011-11-28 11:45:05,000 kernel: com.apple.AppleFSCompressionTypeZlib load succeeded
2011-11-28 11:45:05,000 kernel: com.apple.AppleFSCompressionTypeDataless load succeeded
2011-11-28 11:45:05,000 kernel: AppleIntelCPUPowerManagementClient: ready
2011-11-28 11:45:05,000 kernel: BTCOEXIST off
2011-11-28 11:45:05,000 kernel: wl0: Broadcom BCM432b 802.11 Wireless Controller
2011-11-28 11:45:05,000 kernel: 5.100.98.75
2011-11-28 11:45:05,000 kernel: rooting via boot-uuid from /chosen: B431148B-03FB-3BC2-BB3E-7BCA2BEB0A29
2011-11-28 11:45:05,000 kernel: Waiting on <dict ID="0"><key>IOProviderClass</key><string ID="1">IOResources</string><key>IOResourceMatch</key><string ID="2">boot-uuid-media</string></dict>
2011-11-28 11:45:05,000 kernel: Got boot device = IOService:/AppleACPIPlatformExpert/PCI0@0/AppleACPIPCI/SATA@B/AppleMCP79AHCI/PRT0@0/IOAHCIDevice@0/AppleAHCIDiskDriver/IOAHCIBlockStorageDevice/IOBlockStorageDriver/ST9250410AS Media/IOGUIDPartitionScheme/LION@2
2011-11-28 11:45:05,000 kernel: BSD root: disk0s2, major 14, minor 2
2011-11-28 11:45:05,000 kernel: Kernel is LP64
2011-11-28 11:45:00,020 com.apple.launchd: *** launchd[1] has started up. ***
2011-11-28 11:45:07,000 kernel: NVEthernet: Ethernet address 00:23:32:d2:52:a2
2011-11-28 11:45:07,000 kernel: AirPort_Brcm4331: Ethernet address 00:23:6c:8c:fe:f0
2011-11-28 11:45:07,000 kernel: IO80211Controller::dataLinkLayerAttachComplete():  adding AppleEFINVRAM notification
2011-11-28 11:45:08,992 com.apple.launchd: (com.cisco.anyconnect.vpnagentd[54]) posix_spawn("/opt/cisco/vpn/bin/vpnagentd", ...): No such file or directory
2011-11-28 11:45:08,992 com.apple.launchd: (com.cisco.anyconnect.vpnagentd[54]) Exited with code: 1
2011-11-28 11:45:08,992 com.apple.launchd: (com.cisco.anyconnect.vpnagentd) Throttling respawn: Will start in 10 seconds
2011-11-28 11:45:10,182 com.apple.ucupdate.plist: ucupdate: Checked 1 update, no match found.
2011-11-28 11:45:10,313 com.apple.pfctl: No ALTQ support in kernel
2011-11-28 11:45:10,313 com.apple.pfctl: ALTQ related functions disabled
2011-11-28 11:45:10,542 com.apple.SecurityServer: Session 100000 created
2011-11-28 11:45:11,000 kernel: macx_swapon SUCCESS
2011-11-28 11:45:11,071 com.apple.DumpPanic: 2011-11-28 11:45:10.809 DumpPanic[46:4303] Error getting a reference to IODeviceTree:/options
2011-11-28 11:45:11,073 com.apple.launchd: (com.apple.DumpPanic[46]) Exited with code: 1
2011-11-28 11:45:13,000 kernel: Waiting for DSMOS...
2011-11-28 11:45:13,399 UserEventAgent: starting CaptiveNetworkSupport as SystemEventAgent built Jun 13 2011 17:29:21
2011-11-28 11:45:13,404 UserEventAgent: CaptiveNetworkSupport:CreateInterfaceWatchList:2788 WiFi Devices Found. :)
2011-11-28 11:45:13,404 UserEventAgent: CaptiveNetworkSupport:CaptivePublishState:1211 en1 - PreProbe
2011-11-28 11:45:13,408 UserEventAgent: CaptiveNetworkSupport:CaptiveSCRebuildCache:81 Failed to get service order
2011-11-28 11:45:13,408 UserEventAgent: CaptiveNetworkSupport:CaptivePublishState:1211 en1 - PreProbe
2011-11-28 11:45:13,409 UserEventAgent: CaptiveNetworkSupport:CaptiveSCRebuildCache:81 Failed to get service order
2011-11-28 11:45:13,552 UserEventAgent: CertsKeychainMonitor: configuring
kernel.log (KP1):
Code: Select all
Nov 28 11:45:05 localhost kernel[0]: Darwin Kernel Version 11.2.0: Tue Aug  9 20:54:00 PDT 2011; root:xnu-1699.24.8~1/RELEASE_X86_64
Nov 28 11:45:05 localhost kernel[0]: vm_page_bootstrap: 942082 free pages and 32766 wired pages
Nov 28 11:45:05 localhost kernel[0]: kext submap [0xffffff7f8072e000 - 0xffffff8000000000], kernel text [0xffffff8000200000 - 0xffffff800072e000]
Nov 28 11:45:05 localhost kernel[0]: zone leak detection enabled
Nov 28 11:45:05 localhost kernel[0]: standard timeslicing quantum is 10000 us
Nov 28 11:45:05 localhost kernel[0]: mig_table_max_displ = 73
Nov 28 11:45:05 localhost kernel[0]: AppleACPICPU: ProcessorId=0 LocalApicId=0 Enabled
Nov 28 11:45:05 localhost kernel[0]: AppleACPICPU: ProcessorId=1 LocalApicId=1 Enabled
Nov 28 11:45:05 localhost kernel[0]: calling mpo_policy_init for TMSafetyNet
Nov 28 11:45:05 localhost kernel[0]: Security policy loaded: Safety net for Time Machine (TMSafetyNet)
Nov 28 11:45:05 localhost kernel[0]: calling mpo_policy_init for Sandbox
Nov 28 11:45:05 localhost kernel[0]: Security policy loaded: Seatbelt sandbox policy (Sandbox)
Nov 28 11:45:05 localhost kernel[0]: calling mpo_policy_init for Quarantine
Nov 28 11:45:05 localhost kernel[0]: Security policy loaded: Quarantine policy (Quarantine)
Nov 28 11:45:05 localhost kernel[0]: Copyright (c) 1982, 1986, 1989, 1991, 1993
Nov 28 11:45:05 localhost kernel[0]: The Regents of the University of California. All rights reserved.
Nov 28 11:45:05 localhost kernel[0]: MAC Framework successfully initialized
Nov 28 11:45:05 localhost kernel[0]: using 16384 buffer headers and 10240 cluster IO buffer headers
Nov 28 11:45:05 localhost kernel[0]: IOAPIC: Version 0x11 Vectors 64:87
Nov 28 11:45:05 localhost kernel[0]: ACPI: System State [S0 S3 S4 S5] (S3)
Nov 28 11:45:05 localhost kernel[0]: PFM64 (36 cpu) 0xf10000000, 0xf0000000
Nov 28 11:45:05 localhost kernel[0]: [ PCI configuration begin ]
Nov 28 11:45:05 localhost kernel[0]: console relocated to 0xf20010000
Nov 28 11:45:05 localhost kernel[0]: PCI configuration changed (bridge=6 device=3 cardbus=0)
Nov 28 11:45:05 localhost kernel[0]: [ PCI configuration end, bridges 7 devices 19 ]
Nov 28 11:45:05 localhost kernel[0]: AppleIntelCPUPowerManagement: (built 21:08:10 Aug  9 2011) initialization complete
Nov 28 11:45:05 localhost kernel[0]: FireWire (OHCI) Lucent ID 5901 built-in now active, GUID 002332fffed252a2; max speed s800.
Nov 28 11:45:05 localhost kernel[0]: [IOBluetoothHCIController::setConfigState] calling registerService
Nov 28 11:45:05 localhost kernel[0]: ERROR: FireWire unable to determine security-mode; defaulting to full-secure.
Nov 28 11:45:05 localhost kernel[0]: mbinit: done [64 MB total pool size, (42/21) split]
Nov 28 11:45:05 localhost kernel[0]: Pthread support ABORTS when sync kernel primitives misused
Nov 28 11:45:05 localhost kernel[0]: com.apple.AppleFSCompressionTypeZlib kmod start
Nov 28 11:45:05 localhost kernel[0]: com.apple.AppleFSCompressionTypeDataless kmod start
Nov 28 11:45:05 localhost kernel[0]: com.apple.AppleFSCompressionTypeZlib load succeeded
Nov 28 11:45:05 localhost kernel[0]: com.apple.AppleFSCompressionTypeDataless load succeeded
Nov 28 11:45:05 localhost kernel[0]: AppleIntelCPUPowerManagementClient: ready
Nov 28 11:45:05 localhost kernel[0]: BTCOEXIST off
Nov 28 11:45:05 localhost kernel[0]: wl0: Broadcom BCM432b 802.11 Wireless Controller
Nov 28 11:45:05 localhost kernel[0]: 5.100.98.75
Nov 28 11:45:05 localhost kernel[0]: rooting via boot-uuid from /chosen: B431148B-03FB-3BC2-BB3E-7BCA2BEB0A29
Nov 28 11:45:05 localhost kernel[0]: Waiting on <dict ID="0"><key>IOProviderClass</key><string ID="1">IOResources</string><key>IOResourceMatch</key><string ID="2">boot-uuid-media</string></dict>
Nov 28 11:45:05 localhost kernel[0]: Got boot device = IOService:/AppleACPIPlatformExpert/PCI0@0/AppleACPIPCI/SATA@B/AppleMCP79AHCI/PRT0@0/IOAHCIDevice@0/AppleAHCIDiskDriver/IOAHCIBlockStorageDevice/IOBlockStorageDriver/ST9250410AS Media/IOGUIDPartitionScheme/LION@2
Nov 28 11:45:05 localhost kernel[0]: BSD root: disk0s2, major 14, minor 2
Nov 28 11:45:05 localhost kernel[0]: Kernel is LP64
Nov 28 11:45:07 localhost kernel[0]: NVEthernet: Ethernet address 00:23:32:d2:52:a2
Nov 28 11:45:07 localhost kernel[0]: AirPort_Brcm4331: Ethernet address 00:23:6c:8c:fe:f0
Nov 28 11:45:07 localhost kernel[0]: IO80211Controller::dataLinkLayerAttachComplete():  adding AppleEFINVRAM notification
Nov 28 11:45:11 localhost kernel[0]: macx_swapon SUCCESS
Nov 28 11:45:13 localhost kernel[0]: Waiting for DSMOS...
system.log (KP1):
Code: Select all
Nov 28 11:44:58 localhost bootlog[0]: BOOT_TIME 1322477098 0
Nov 28 11:45:00 localhost com.apple.launchd[1]: *** launchd[1] has started up. ***
Nov 28 11:45:08 localhost com.apple.launchd[1] (com.cisco.anyconnect.vpnagentd[54]): posix_spawn("/opt/cisco/vpn/bin/vpnagentd", ...): No such file or directory
Nov 28 11:45:08 localhost com.apple.launchd[1] (com.cisco.anyconnect.vpnagentd[54]): Exited with code: 1
Nov 28 11:45:08 localhost com.apple.launchd[1] (com.cisco.anyconnect.vpnagentd): Throttling respawn: Will start in 10 seconds
Nov 28 11:45:10 localhost com.apple.ucupdate.plist[24]: ucupdate: Checked 1 update, no match found.
Nov 28 11:45:10 localhost com.apple.pfctl[33]: No ALTQ support in kernel
Nov 28 11:45:10 localhost com.apple.pfctl[33]: ALTQ related functions disabled
Nov 28 11:45:11 localhost DumpPanic[46]: Error getting a reference to IODeviceTree:/options
Nov 28 11:45:11 localhost com.apple.DumpPanic[46]: 2011-11-28 11:45:10.809 DumpPanic[46:4303] Error getting a reference to IODeviceTree:/options
Nov 28 11:45:11 localhost com.apple.launchd[1] (com.apple.DumpPanic[46]): Exited with code: 1
Nov 28 11:45:13 localhost UserEventAgent[11]: starting CaptiveNetworkSupport as SystemEventAgent built Jun 13 2011 17:29:21
Nov 28 11:45:13 localhost UserEventAgent[11]: CaptiveNetworkSupport:CreateInterfaceWatchList:2788 WiFi Devices Found. :)
Nov 28 11:45:13 localhost UserEventAgent[11]: CaptiveNetworkSupport:CaptivePublishState:1211 en1 - PreProbe
Nov 28 11:45:13 localhost UserEventAgent[11]: CaptiveNetworkSupport:CaptiveSCRebuildCache:81 Failed to get service order
Nov 28 11:45:13: --- last message repeated 1 time ---
Nov 28 11:45:13 localhost UserEventAgent[11]: CertsKeychainMonitor: configuring
Kernel panic #2
Picture of KP2:
https://docs.google.com/open?id=0B39rsO ... Q4YThhOGFm
All Message Log (KP2):
Code: Select all
2011-11-28 11:48:42,000 bootlog: BOOT_TIME 1322477322 0
2011-11-28 11:48:51,000 kernel: Darwin Kernel Version 11.2.0: Tue Aug  9 20:54:00 PDT 2011; root:xnu-1699.24.8~1/RELEASE_X86_64
2011-11-28 11:48:51,000 kernel: vm_page_bootstrap: 942082 free pages and 32766 wired pages
2011-11-28 11:48:51,000 kernel: kext submap [0xffffff7f8072e000 - 0xffffff8000000000], kernel text [0xffffff8000200000 - 0xffffff800072e000]
2011-11-28 11:48:51,000 kernel: zone leak detection enabled
2011-11-28 11:48:51,000 kernel: standard timeslicing quantum is 10000 us
2011-11-28 11:48:51,000 kernel: mig_table_max_displ = 73
2011-11-28 11:48:51,000 kernel: AppleACPICPU: ProcessorId=0 LocalApicId=0 Enabled
2011-11-28 11:48:51,000 kernel: AppleACPICPU: ProcessorId=1 LocalApicId=1 Enabled
2011-11-28 11:48:51,000 kernel: calling mpo_policy_init for TMSafetyNet
2011-11-28 11:48:51,000 kernel: Security policy loaded: Safety net for Time Machine (TMSafetyNet)
2011-11-28 11:48:51,000 kernel: calling mpo_policy_init for Sandbox
2011-11-28 11:48:51,000 kernel: Security policy loaded: Seatbelt sandbox policy (Sandbox)
2011-11-28 11:48:51,000 kernel: calling mpo_policy_init for Quarantine
2011-11-28 11:48:51,000 kernel: Security policy loaded: Quarantine policy (Quarantine)
2011-11-28 11:48:51,000 kernel: Copyright (c) 1982, 1986, 1989, 1991, 1993
2011-11-28 11:48:51,000 kernel: The Regents of the University of California. All rights reserved.
2011-11-28 11:48:51,000 kernel: MAC Framework successfully initialized
2011-11-28 11:48:51,000 kernel: using 16384 buffer headers and 10240 cluster IO buffer headers
2011-11-28 11:48:51,000 kernel: IOAPIC: Version 0x11 Vectors 64:87
2011-11-28 11:48:51,000 kernel: ACPI: System State [S0 S3 S4 S5] (S3)
2011-11-28 11:48:51,000 kernel: PFM64 (36 cpu) 0xf10000000, 0xf0000000
2011-11-28 11:48:51,000 kernel: [ PCI configuration begin ]
2011-11-28 11:48:51,000 kernel: console relocated to 0xf20010000
2011-11-28 11:48:51,000 kernel: PCI configuration changed (bridge=6 device=3 cardbus=0)
2011-11-28 11:48:51,000 kernel: [ PCI configuration end, bridges 7 devices 19 ]
2011-11-28 11:48:51,000 kernel: AppleIntelCPUPowerManagement: (built 21:08:10 Aug  9 2011) initialization complete
2011-11-28 11:48:51,000 kernel: FireWire (OHCI) Lucent ID 5901 built-in now active, GUID 002332fffed252a2; max speed s800.
2011-11-28 11:48:51,000 kernel: [IOBluetoothHCIController::setConfigState] calling registerService
2011-11-28 11:48:51,000 kernel: ERROR: FireWire unable to determine security-mode; defaulting to full-secure.
2011-11-28 11:48:51,000 kernel: mbinit: done [64 MB total pool size, (42/21) split]
2011-11-28 11:48:51,000 kernel: Pthread support ABORTS when sync kernel primitives misused
2011-11-28 11:48:51,000 kernel: com.apple.AppleFSCompressionTypeZlib kmod start
2011-11-28 11:48:51,000 kernel: com.apple.AppleFSCompressionTypeDataless kmod start
2011-11-28 11:48:51,000 kernel: com.apple.AppleFSCompressionTypeZlib load succeeded
2011-11-28 11:48:51,000 kernel: com.apple.AppleFSCompressionTypeDataless load succeeded
2011-11-28 11:48:51,000 kernel: AppleIntelCPUPowerManagementClient: ready
2011-11-28 11:48:51,000 kernel: BTCOEXIST off
2011-11-28 11:48:51,000 kernel: wl0: Broadcom BCM432b 802.11 Wireless Controller
2011-11-28 11:48:51,000 kernel: 5.100.98.75
2011-11-28 11:48:51,000 kernel: rooting via boot-uuid from /chosen: B431148B-03FB-3BC2-BB3E-7BCA2BEB0A29
2011-11-28 11:48:51,000 kernel: Waiting on <dict ID="0"><key>IOProviderClass</key><string ID="1">IOResources</string><key>IOResourceMatch</key><string ID="2">boot-uuid-media</string></dict>
2011-11-28 11:48:51,000 kernel: Got boot device = IOService:/AppleACPIPlatformExpert/PCI0@0/AppleACPIPCI/SATA@B/AppleMCP79AHCI/PRT0@0/IOAHCIDevice@0/AppleAHCIDiskDriver/IOAHCIBlockStorageDevice/IOBlockStorageDriver/ST9250410AS Media/IOGUIDPartitionScheme/LION@2
2011-11-28 11:48:51,000 kernel: BSD root: disk0s2, major 14, minor 2
2011-11-28 11:48:51,000 kernel: jnl: unknown-dev: replay_journal: from: 5649408 to: 9708544 (joffset 0x747000)
2011-11-28 11:48:51,000 kernel: jnl: unknown-dev: journal replay done.
2011-11-28 11:48:51,000 kernel: Kernel is LP64
2011-11-28 11:48:51,000 kernel: hfs: Removed 0 orphaned / unlinked files and 6 directories
2011-11-28 11:48:46,376 com.apple.launchd: *** launchd[1] has started up. ***
2011-11-28 11:48:53,000 kernel: NVEthernet: Ethernet address 00:23:32:d2:52:a2
2011-11-28 11:48:53,000 kernel: AirPort_Brcm4331: Ethernet address 00:23:6c:8c:fe:f0
2011-11-28 11:48:53,000 kernel: IO80211Controller::dataLinkLayerAttachComplete():  adding AppleEFINVRAM notification
2011-11-28 11:48:55,119 com.apple.launchd: (com.cisco.anyconnect.vpnagentd[54]) posix_spawn("/opt/cisco/vpn/bin/vpnagentd", ...): No such file or directory
2011-11-28 11:48:55,120 com.apple.launchd: (com.cisco.anyconnect.vpnagentd[54]) Exited with code: 1
2011-11-28 11:48:55,120 com.apple.launchd: (com.cisco.anyconnect.vpnagentd) Throttling respawn: Will start in 10 seconds
2011-11-28 11:48:55,473 com.apple.pfctl: No ALTQ support in kernel
2011-11-28 11:48:55,473 com.apple.pfctl: ALTQ related functions disabled
2011-11-28 11:48:55,823 com.apple.ucupdate.plist: ucupdate: Checked 1 update, no match found.
2011-11-28 11:48:55,886 fseventsd: event logs in /.fseventsd out of sync with volume.  destroying old logs. (171 12 336)
2011-11-28 11:48:56,589 fseventsd: log dir: /.fseventsd getting new uuid: 1259FC9A-89C4-463B-A803-827EF26804C1
2011-11-28 11:48:56,646 com.apple.DumpPanic: 2011-11-28 11:48:56.498 DumpPanic[46:4303] Error getting a reference to IODeviceTree:/options
2011-11-28 11:48:56,652 com.apple.launchd: (com.apple.DumpPanic[46]) Exited with code: 1
2011-11-28 11:48:57,000 kernel: macx_swapon SUCCESS
2011-11-28 11:48:57,026 com.apple.SecurityServer: Session 100000 created
2011-11-28 11:48:58,641 UserEventAgent: starting CaptiveNetworkSupport as SystemEventAgent built Jun 13 2011 17:29:21
2011-11-28 11:48:58,645 UserEventAgent: CaptiveNetworkSupport:CreateInterfaceWatchList:2788 WiFi Devices Found. :)
2011-11-28 11:48:58,645 UserEventAgent: CaptiveNetworkSupport:CaptivePublishState:1211 en1 - PreProbe
2011-11-28 11:48:58,645 UserEventAgent: CaptiveNetworkSupport:CaptiveSCRebuildCache:81 Failed to get service order
2011-11-28 11:48:58,646 UserEventAgent: CaptiveNetworkSupport:CaptiveSCRebuildCache:81 Failed to get service order
2011-11-28 11:48:58,971 UserEventAgent: CertsKeychainMonitor: configuring
2011-11-28 11:48:59,000 kernel: Waiting for DSMOS...
kernel.log (KP2):
Code: Select all
Nov 28 11:48:51 localhost kernel[0]: Darwin Kernel Version 11.2.0: Tue Aug  9 20:54:00 PDT 2011; root:xnu-1699.24.8~1/RELEASE_X86_64
Nov 28 11:48:51 localhost kernel[0]: vm_page_bootstrap: 942082 free pages and 32766 wired pages
Nov 28 11:48:51 localhost kernel[0]: kext submap [0xffffff7f8072e000 - 0xffffff8000000000], kernel text [0xffffff8000200000 - 0xffffff800072e000]
Nov 28 11:48:51 localhost kernel[0]: zone leak detection enabled
Nov 28 11:48:51 localhost kernel[0]: standard timeslicing quantum is 10000 us
Nov 28 11:48:51 localhost kernel[0]: mig_table_max_displ = 73
Nov 28 11:48:51 localhost kernel[0]: AppleACPICPU: ProcessorId=0 LocalApicId=0 Enabled
Nov 28 11:48:51 localhost kernel[0]: AppleACPICPU: ProcessorId=1 LocalApicId=1 Enabled
Nov 28 11:48:51 localhost kernel[0]: calling mpo_policy_init for TMSafetyNet
Nov 28 11:48:51 localhost kernel[0]: Security policy loaded: Safety net for Time Machine (TMSafetyNet)
Nov 28 11:48:51 localhost kernel[0]: calling mpo_policy_init for Sandbox
Nov 28 11:48:51 localhost kernel[0]: Security policy loaded: Seatbelt sandbox policy (Sandbox)
Nov 28 11:48:51 localhost kernel[0]: calling mpo_policy_init for Quarantine
Nov 28 11:48:51 localhost kernel[0]: Security policy loaded: Quarantine policy (Quarantine)
Nov 28 11:48:51 localhost kernel[0]: Copyright (c) 1982, 1986, 1989, 1991, 1993
Nov 28 11:48:51 localhost kernel[0]: The Regents of the University of California. All rights reserved.
Nov 28 11:48:51 localhost kernel[0]: MAC Framework successfully initialized
Nov 28 11:48:51 localhost kernel[0]: using 16384 buffer headers and 10240 cluster IO buffer headers
Nov 28 11:48:51 localhost kernel[0]: IOAPIC: Version 0x11 Vectors 64:87
Nov 28 11:48:51 localhost kernel[0]: ACPI: System State [S0 S3 S4 S5] (S3)
Nov 28 11:48:51 localhost kernel[0]: PFM64 (36 cpu) 0xf10000000, 0xf0000000
Nov 28 11:48:51 localhost kernel[0]: [ PCI configuration begin ]
Nov 28 11:48:51 localhost kernel[0]: console relocated to 0xf20010000
Nov 28 11:48:51 localhost kernel[0]: PCI configuration changed (bridge=6 device=3 cardbus=0)
Nov 28 11:48:51 localhost kernel[0]: [ PCI configuration end, bridges 7 devices 19 ]
Nov 28 11:48:51 localhost kernel[0]: AppleIntelCPUPowerManagement: (built 21:08:10 Aug  9 2011) initialization complete
Nov 28 11:48:51 localhost kernel[0]: FireWire (OHCI) Lucent ID 5901 built-in now active, GUID 002332fffed252a2; max speed s800.
Nov 28 11:48:51 localhost kernel[0]: [IOBluetoothHCIController::setConfigState] calling registerService
Nov 28 11:48:51 localhost kernel[0]: ERROR: FireWire unable to determine security-mode; defaulting to full-secure.
Nov 28 11:48:51 localhost kernel[0]: mbinit: done [64 MB total pool size, (42/21) split]
Nov 28 11:48:51 localhost kernel[0]: Pthread support ABORTS when sync kernel primitives misused
Nov 28 11:48:51 localhost kernel[0]: com.apple.AppleFSCompressionTypeZlib kmod start
Nov 28 11:48:51 localhost kernel[0]: com.apple.AppleFSCompressionTypeDataless kmod start
Nov 28 11:48:51 localhost kernel[0]: com.apple.AppleFSCompressionTypeZlib load succeeded
Nov 28 11:48:51 localhost kernel[0]: com.apple.AppleFSCompressionTypeDataless load succeeded
Nov 28 11:48:51 localhost kernel[0]: AppleIntelCPUPowerManagementClient: ready
Nov 28 11:48:51 localhost kernel[0]: BTCOEXIST off
Nov 28 11:48:51 localhost kernel[0]: wl0: Broadcom BCM432b 802.11 Wireless Controller
Nov 28 11:48:51 localhost kernel[0]: 5.100.98.75
Nov 28 11:48:51 localhost kernel[0]: rooting via boot-uuid from /chosen: B431148B-03FB-3BC2-BB3E-7BCA2BEB0A29
Nov 28 11:48:51 localhost kernel[0]: Waiting on <dict ID="0"><key>IOProviderClass</key><string ID="1">IOResources</string><key>IOResourceMatch</key><string ID="2">boot-uuid-media</string></dict>
Nov 28 11:48:51 localhost kernel[0]: Got boot device = IOService:/AppleACPIPlatformExpert/PCI0@0/AppleACPIPCI/SATA@B/AppleMCP79AHCI/PRT0@0/IOAHCIDevice@0/AppleAHCIDiskDriver/IOAHCIBlockStorageDevice/IOBlockStorageDriver/ST9250410AS Media/IOGUIDPartitionScheme/LION@2
Nov 28 11:48:51 localhost kernel[0]: BSD root: disk0s2, major 14, minor 2
Nov 28 11:48:51 localhost kernel[0]: jnl: unknown-dev: replay_journal: from: 5649408 to: 9708544 (joffset 0x747000)
Nov 28 11:48:51 localhost kernel[0]: jnl: unknown-dev: journal replay done.
Nov 28 11:48:51 localhost kernel[0]: Kernel is LP64
Nov 28 11:48:51 localhost kernel[0]: hfs: Removed 0 orphaned / unlinked files and 6 directories
Nov 28 11:48:53 localhost kernel[0]: NVEthernet: Ethernet address 00:23:32:d2:52:a2
Nov 28 11:48:53 localhost kernel[0]: AirPort_Brcm4331: Ethernet address 00:23:6c:8c:fe:f0
Nov 28 11:48:53 localhost kernel[0]: IO80211Controller::dataLinkLayerAttachComplete():  adding AppleEFINVRAM notification
Nov 28 11:48:57 localhost kernel[0]: macx_swapon SUCCESS
Nov 28 11:48:59 localhost kernel[0]: Waiting for DSMOS...
system.log (KP2):
Code: Select all
Nov 28 11:48:42 localhost bootlog[0]: BOOT_TIME 1322477322 0
Nov 28 11:48:46 localhost com.apple.launchd[1]: *** launchd[1] has started up. ***
Nov 28 11:48:55 localhost com.apple.launchd[1] (com.cisco.anyconnect.vpnagentd[54]): posix_spawn("/opt/cisco/vpn/bin/vpnagentd", ...): No such file or directory
Nov 28 11:48:55 localhost com.apple.launchd[1] (com.cisco.anyconnect.vpnagentd[54]): Exited with code: 1
Nov 28 11:48:55 localhost com.apple.launchd[1] (com.cisco.anyconnect.vpnagentd): Throttling respawn: Will start in 10 seconds
Nov 28 11:48:55 localhost com.apple.pfctl[33]: No ALTQ support in kernel
Nov 28 11:48:55 localhost com.apple.pfctl[33]: ALTQ related functions disabled
Nov 28 11:48:55 localhost com.apple.ucupdate.plist[24]: ucupdate: Checked 1 update, no match found.
Nov 28 11:48:55 localhost fseventsd[43]: event logs in /.fseventsd out of sync with volume.  destroying old logs. (171 12 336)
Nov 28 11:48:56 localhost fseventsd[43]: log dir: /.fseventsd getting new uuid: 1259FC9A-89C4-463B-A803-827EF26804C1
Nov 28 11:48:56 localhost DumpPanic[46]: Error getting a reference to IODeviceTree:/options
Nov 28 11:48:56 localhost com.apple.DumpPanic[46]: 2011-11-28 11:48:56.498 DumpPanic[46:4303] Error getting a reference to IODeviceTree:/options
Nov 28 11:48:56 localhost com.apple.launchd[1] (com.apple.DumpPanic[46]): Exited with code: 1
Nov 28 11:48:58 localhost UserEventAgent[11]: starting CaptiveNetworkSupport as SystemEventAgent built Jun 13 2011 17:29:21
Nov 28 11:48:58 localhost UserEventAgent[11]: CaptiveNetworkSupport:CreateInterfaceWatchList:2788 WiFi Devices Found. :)
Nov 28 11:48:58 localhost UserEventAgent[11]: CaptiveNetworkSupport:CaptivePublishState:1211 en1 - PreProbe
Nov 28 11:48:58 localhost UserEventAgent[11]: CaptiveNetworkSupport:CaptiveSCRebuildCache:81 Failed to get service order
Nov 28 11:48:58: --- last message repeated 1 time ---
Nov 28 11:48:58 localhost UserEventAgent[11]: CertsKeychainMonitor: configuring
wove
Re: Kernel panic at boot, safe boot works fine
Post by wove »
A couple of the panics seem related to this from your log:
"Error getting a reference to IODeviceTree:/options"
The IODeviceTree begins as part of open firmware. You can access it by holding down command-option-o-f during boot. The following commands issued from the Firmware prompt will reset the open firmware:
reset-nvram
set-defaults
reset-all
Your Mac will then restart.
Problems with the device tree could also be caused by hardware problems. Booting into single user mode by starting in single user mode (startup holding down command S) and running this at the prompt:
fsck -fy
Will check and repair the hard drive.
bill
\/\/i||i@m ()\/e
leonAzul
Post by leonAzul »
All Intel-based Macs are EFI-based. Open Firmware will go extinct when the last of the PowerPC Macs have been retired.
To reset the PRAM, "cnd + opt + P + R" does still work, and might actually help since a reset would cause the computer to rescan the motherboard for available devices instead of looking for something that is not there anymore.
There is an error trying to launch "com.cisco.anyconnect.vpnagentd". The log reads:
Does this look like something you have installed?
I am wondering if this is really the case, or whether it indicates a problem with one of your network interfaces, perhaps EN0 (the ethernet card on the motherboard)? Was there ever a time when this computer expected an external NIC at startup?
Just to clarify, when you wrote "safe boot", did you mean "single-user mode"?
edited to add:
Here is link to the key bindings available at startup for an MBP.
http://support.apple.com/kb/HT1533
antoniotony
Post by antoniotony »
Code: Select all
1/28/13 1:02:40 PM	bootlog[40]	BOOT_TIME: 1359395776 0
1/28/13 1:03:10 PM	kernel	Darwin Kernel Version 10.4.2: Tue Jul 27 21:17:17 PDT 2010; root:xnu-1504.7.60~1/RELEASE_X86_64
1/28/13 1:03:10 PM	kernel	vm_page_bootstrap: 1979884 free pages and 117268 wired pages
1/28/13 1:03:10 PM	kernel	kext submap [0xffffff7f80600000 - 0xffffff8000000000], kernel text [0xffffff8000200000 - 0xffffff8000600000]
1/28/13 1:03:10 PM	kernel	standard timeslicing quantum is 10000 us
1/28/13 1:03:10 PM	kernel	mig_table_max_displ = 73
1/28/13 1:03:10 PM	kernel	AppleACPICPU: ProcessorId=0 LocalApicId=0 Enabled
1/28/13 1:03:10 PM	kernel	AppleACPICPU: ProcessorId=1 LocalApicId=32 Enabled
1/28/13 1:03:10 PM	kernel	AppleACPICPU: ProcessorId=2 LocalApicId=2 Enabled
1/28/13 1:03:10 PM	kernel	AppleACPICPU: ProcessorId=3 LocalApicId=34 Enabled
1/28/13 1:03:10 PM	kernel	AppleACPICPU: ProcessorId=4 LocalApicId=18 Enabled
1/28/13 1:03:10 PM	kernel	AppleACPICPU: ProcessorId=5 LocalApicId=50 Enabled
1/28/13 1:03:10 PM	kernel	AppleACPICPU: ProcessorId=6 LocalApicId=20 Enabled
1/28/13 1:03:10 PM	kernel	AppleACPICPU: ProcessorId=7 LocalApicId=52 Enabled
1/28/13 1:03:10 PM	kernel	AppleACPICPU: ProcessorId=8 LocalApicId=1 Enabled
1/28/13 1:03:10 PM	kernel	AppleACPICPU: ProcessorId=9 LocalApicId=33 Enabled
1/28/13 1:03:10 PM	kernel	AppleACPICPU: ProcessorId=10 LocalApicId=3 Enabled
1/28/13 1:03:10 PM	kernel	AppleACPICPU: ProcessorId=11 LocalApicId=35 Enabled
1/28/13 1:03:10 PM	kernel	AppleACPICPU: ProcessorId=12 LocalApicId=19 Enabled
1/28/13 1:03:10 PM	kernel	AppleACPICPU: ProcessorId=13 LocalApicId=51 Enabled
1/28/13 1:03:10 PM	kernel	AppleACPICPU: ProcessorId=14 LocalApicId=21 Enabled
1/28/13 1:03:10 PM	kernel	AppleACPICPU: ProcessorId=15 LocalApicId=53 Enabled
1/28/13 1:03:10 PM	kernel	AppleACPICPU: ProcessorId=16 LocalApicId=0 Disabled
1/28/13 1:03:10 PM	kernel	AppleACPICPU: ProcessorId=17 LocalApicId=0 Disabled
1/28/13 1:03:10 PM	kernel	AppleACPICPU: ProcessorId=18 LocalApicId=0 Disabled
1/28/13 1:03:10 PM	kernel	AppleACPICPU: ProcessorId=19 LocalApicId=0 Disabled
1/28/13 1:03:10 PM	kernel	AppleACPICPU: ProcessorId=20 LocalApicId=0 Disabled
1/28/13 1:03:10 PM	kernel	AppleACPICPU: ProcessorId=21 LocalApicId=0 Disabled
1/28/13 1:03:10 PM	kernel	AppleACPICPU: ProcessorId=22 LocalApicId=0 Disabled
1/28/13 1:03:10 PM	kernel	AppleACPICPU: ProcessorId=23 LocalApicId=0 Disabled
1/28/13 1:03:10 PM	kernel	calling mpo_policy_init for Quarantine
1/28/13 1:03:10 PM	kernel	Security policy loaded: Quarantine policy (Quarantine)
1/28/13 1:03:10 PM	kernel	calling mpo_policy_init for Sandbox
1/28/13 1:03:10 PM	kernel	Security policy loaded: Seatbelt sandbox policy (Sandbox)
1/28/13 1:03:10 PM	kernel	calling mpo_policy_init for TMSafetyNet
1/28/13 1:03:10 PM	kernel	Security policy loaded: Safety net for Time Machine
