ComboBox 1.2
External modules for 4D.
ComboBox 1.2
Post by Info-Mac » August 30th, 1996, 9:00 am
Download: http://archive.info-mac.org/dev/db/a4d/ ... box-12.hqx
This is version 1.2 of Pensacola Christian College's freeware ComboBox
external area for 4th Dimension. The following changes have been made
since the 1.1.1 release:
o Enabled the Paste menu item when appropriate.
o Made sure that the selected item in the list box always stays in sync
with the text in the editable area.
o Closed the list box window on the first idle event after the layout
window is moved.
o Used the black & white PICT resource for the popup-indicator button
on display devices having four (4) or fewer colors.
o Eliminated the last vestiges of the dead scroll bar problem.
o Allowed string arrays to be used for CB_FillLst() rather than requiring
all arrays to be of type text.
o Added CB_GetContRef() function to make ComboBox compatible with
Foresight Technology's "Container" and Automated Solutions Group's
"Habitat."
o Added DrawBox flag to CB_DefSetFlags() and CB_SetFlags().
o Made the list window show up in the right place (above vs. below the
area) even on monitors other than the main monitor.
o Started using the real arrow cursor.
o Corrected a bug in which a compiled database would execute the
ComboBox's script twice when a button was clicked, considering it
unmodified both times.
o Fixed a bug where the text-entry area did not reflect the new size
after the font was changed.
