Automatic Chooser Ext
External modules for 4D.
Download: http://archive.info-mac.org/dev/db/a4d/ ... er-ext.hqx
To: [email protected]
X-VMS-To: IN%"[email protected]"
AutoChoose
AutoChoose will replace many of the features of Apple's Chooser within your 4th Dimension program.
For example You have a Laserwriter and a local Imagewriter. You want your reports to be printed on the Imagewriter and the other information to be printed on the Laserwriter, you would have to go to Chooser each time you change. AutoChoose allows you
System 6.0x only Not System 7.0 compatible
