TidBITS2html 1.2b
TidBITS2html 1.2b
Post by Info-Mac » October 2nd, 1997, 9:00 am
Download: http://archive.info-mac.org/dev/dtt/tid ... l-120b.hqx
TidBITS2html 1.2 is an application produced with Data Transformer Project
Manager 0.9a10 available on Info-Mac. It transforms an emailed TidBITS type
of document into HTML.
To try 'TidBITS2html App' either drag and drop a textfile on
it or start it and open a textfile from inside it.
The minimum system required for the 'TidBITS2html App' is a Macintosh
LC (Motorola 68020), running MacOS 7.0 or later (Systems before version 7.5
also require the Thread Manager extension, available for free from Apple).
In order to look inside 'TidBITS2html App' and its graphs must you have Data
Transformer Project Manager 0.9a10 or later.
To compile the project you will also need a C/C++ compiler from a
third party vendor, such as Metrowerks or Symantec.
More information about this application is available on the net:
/Jens Malmgren
"Richard Of York Gave Battle In Vain" - The end of the story?
