Download: http://archive.info-mac.org/dev/dtt/com ... er-11b.hqx
CommentExcerpter 1.1 is an application produced with Data Transformer Project
Manager 0.9a10 available on Info-Mac. It extracts the comments out from C source
code.
To try 'CommentExcerpter App' either drag and drop a textfile on
it or start it and open a textfile from inside it.
The minimum system required for the 'CommentExcerpter App' is a Macintosh
LC (Motorola 68020), running MacOS 7.0 or later (Systems before version 7.5
also require the Thread Manager extension, available for free from Apple).
In order to look inside 'CommentExcerpter App' and its graphs must you have Data
Transformer Project Manager 0.9a10 or later.
To compile the project you will also need a C/C++ compiler from a
third party vendor, such as Metrowerks or Symantec.
More information about this application is available on the net:
/Jens Malmgren
[email protected]
"Richard Of York Gave Battle In Vain" - The end of the story?
