sndcompiler.sit.hqx
sndcompiler.sit.hqx
Download: http://archive.info-mac.org/dev/snd-compiler.hqx
snd Compiler
Matthew Dolan
©1999, Tri-Bar.
http://www.tribar.dabsol.co.uk/
snd Compiler is a small compiler plug-in for use with CodeWarrior. It allows
the adding of various sound formats to the project. It automatically
converts these to 'snd ' resources whatever file type they are.
Requires:
CodeWarrior 9 or better
QuickTime 2.0 or better
snd Compiler is shareware, and as such if you continue to use it for more
than 30 days you should pay the $5 license fee (£2.50 UK).
